TwinTurbo.NET: Nissan 300ZX forum - Thanks, I was not sure if the JDM maps were more aggressive
Chip(GinnMotorsports)
on March 25, 2003 at 1:13 PM
Chip, the tuned bins are using the stock JDM timing map
posted by Z from Japan
on March 24, 2003 at 08:08 PM
across the board, or just under boost. Thanks!
How to Tune the 300Z ECU Revision 1
Z from Japan
08:07:13 03/24/03
Description of new tuned .bin files
Z from Japan
08:14:22 03/24/03
As always....Thanks for sharing the knowledge :-)....... (n/m)
Kyle(Houston)
08:41:55 03/24/03
BTW...Your driving is good ;-).......... (n/m)
Kyle(Houston)
17:10:40 03/24/03
domo arigato mr roboto \(^^)/ (n/m)
Z from Japan
20:13:47 03/24/03
Aren't there differences in the fuel additives --->
Todd@Z1 Motorsports
11:37:27 03/24/03
Whut???
Z from Japan
20:21:27 03/24/03
Thanks, but I think you'll find MON and RON ---->
Todd@Z1 Motorsports
08:45:20 03/25/03
The only possibility that I can see for alterations in the
Z from Japan
23:52:42 03/26/03
Do you have any timing maps that will work with US spec fuel
15:58:37 03/24/03
Z from Japan
20:08:29 03/24/03
Thanks, I was not sure if the JDM maps were more aggressive -
13:13:32 03/25/03
Done any work with '95 programs? (n/m)
mm_95TT
22:17:31 03/24/03
Most (if not all) 95 Z32's have 16bit ECUs.
Steve Simmons
00:37:38 03/25/03
That's why I asked
mm_95TT
10:26:40 03/25/03
The problem lies in the daughter boards
Z from Japan
23:39:53 03/26/03
I don't think they need 2 EEPROMs
mm_95TT
12:23:18 03/30/03
